[ Все|другие модели ] удалить
  • Автор теми Автор теми shamritsky
shamritsky
Харьков
200 C8 Подогреваемый докаталитический лямбда-зонд, цилиндры 1, 2 и 3
Нашел у себя в талмудах. Подкиньте для начала исправный ЛЗ.
Чьи мозги в машине Сименс MS40/MS40.1, или Борщ ?
Если мозги БОРЩ, ошибка 200 красным - вафельки блоку
DME M1.7, M1.7.1, M1.7.2, M3.1 and M3.3
Decimal
1 Fuel Pump Relay or RPM Signal
2 Idle-Speed Controller
3 Injectors (4cyl-1,3; 6/8cyl-1,5; 12cyl 2,4,6 or 8,10,12)
4 Injectors (DME 3.3.1 Cyl 4,6)
5 Injectors (DME 3.3.1 Cyl 3,5)
6 Injectors- General
7 VANOS Relay or Injector cyl6 (DME 1.7.2)
8 "CHECK ENGINE" Light Failure
12 TPS or Lambda Sensor (M3.3.1)
13 Lambda Probe
15 Knock Sensor 1 (DME 1.7/DME 3.1)or Ignition Fault (DME 1.7.2)
16 Ignition System or Cam/Crank Position Sensor
17 Cam Position Sensor
18 DISA Valve (DME 1.7.2)
19 Electric Fan Output Stage
20 Cruise Control
22 Ignition Fault Cyl 7
23 Ignition Fault Cyl 4 or 6
24 Ignition Fault Cyl 4 or 6
25 Ignition Fault Cyl 1 or 5
26 Voltage Supply
29 Idle Speed Controller
31 Injector on Cyl 3 or 5
32 Injectors (4cyl 2/4; 6cyl 2/6; 8cyl 8/2; 12cyl 1,3,5 or 7,9,11)
33 Injector on Cyl 1 or 3
35 Injector on Cyl 2
36 EVAP Canister Valve
37 Lambda Heater Relay
38 Lambda Heater Relay
41 Air Flow Sensor
42 Speed Signal or Knock Sensor 2 (DME 1.7.x or 3.3.1)
46 Electric Fan
48 AirCon Compressor Shut Off Relay
49 Injector on Cyl 2
50 Ignition Fault on Cyl 1 or 3
51 Ignition Fault on Cyl 2 or 8
52 Ignition Fault on Cyl 5 or 3
54 Voltage Supply
55 Ignition (Final Stage)
62 Signal (EML)
63 Torque Converter Lockup Clutch
64 EGS/DME Connection Error
65 AirCon Compressor
66 Theft Warning System (DWA)
67 Crank Position Sensor or Knock Sensor 4 (DME 3.3)
68 Knock Sensor 3
69 Knock Sensor 2
70 Lambda Sensor (DME 1.7.x or 3.1) or Knock Sensor 1
73 Vehicle Speed Signal (VSS) or TPS
76 Idle Speed Setting - CO Adjustor
77 Intake Air Temperature Sensor
78 Coolant Temperature Sensor
81 Theft Warning System (DWA)
82 MSR Engine Torque Regulation or AirCon Compressor (1.7.2)
83 ASC (EML)
85 AirCon Compressor Relay
100 Amplifier 1 in DME Control Unit
101 Amplifier 2 in DME Control Unit
150 Knock Sensor 1
151 Knock Sensor 2
152 Knock Control
153 Knock Control Voltage
200 DME Control Unit
201 Lambda Regulation
202 Control unit
203 Ignition system or Lambda Sensor
204 Idle Speed (EML)
205 Ignition Timing Intervention
206 Knock Control Test Pulse/Control Modules
207 Knock Control Regulated Voltage
210 CAN Interface
220 EWS 2 Immobilisation
252 EVAP Canister Valve
255 Control Unit -Internal error
333 Control Unit -Internal error
Если мозги сименс, то лямбда - красным ошибка 200
MS40
Decimal
1 Ignition Fault Cylinder 1
2 Ignition Fault Cylinder 3
3 Ignition Fault Cylinder 5
5 Injector Fault Cylinder 6
6 Injector Fault Cylinder 4
8 Park/Neutral Switch
9 AirCon Compressor
10 AirCon Pressure Switch
12 Vehicle Speed Signal
14 EGS/DME Connection Error
15 EWS
22 Injector Fault Cylinder 3
23 Injector Fault Cylinder 1
24 AirCon Compressor
25 Vanos
27 Idle Speed Controller
29 Ignition Fault Cylinder 2
30 Ignition Fault Cylinder 4
31 Ignition Fault Cylinder 6
33 Injector Fault Cylinder 5
49 Power Supply Control Unit
50 Injector Fault Cylinder 2
51 Tank Ventilation
52 Fuel Pump
53 Lambda Sensor Heater
62 Ignition Signal Resistor
63 Knock Sensor Fault Bank 2
64 Knock Sensor Fault Bank 1
68 Air Flow Sensor (HFM)
75 Lambda Sensor Voltage
77 TPS
79 Cam Position Sensor
81 Coolant Temperature Sensor
84 Camshaft Sensor
85 Intake Air Temperature Sensor
97 Tank Ventilation Valve
98 Idle Speed Controller
99 Lambda Regulation
100 Control Unit Fault
200 Lambda Sensor Control
201 Idle Speed Controller
203 TPS
204 Ignition Signal Resistor
206 Vanos Mechanical Fault
207 Vehicle Speed Signal VSS
209 EWS Intervention
Посмотрю какие мозги.
А вообще такое поведение авто совпадает с ошибкой?Может ошибка ошибкой,а причина другая?Это я уточняю,что-бы всю машину не в итоге не перебрать :-)
Нерабочий ЛЗ => неправильная смесь. Причем тут вся машина? Я же написал или то, или то в зависимости от мозгов. Коды ошибок для кого то же писали в зависимости от ЭБУ ДВС?
Ок,понял,спасибо.
